vcLinkJoint
A joint that connects two vcNodes.
Module: vcRobotics2
Children: vcSingleDofLinkJoint
Referenced by: vcComponent.Joints, vcLinkNode.Joints, vcLinkNode.createJoint()
ChildNodevcLinkNodeRWGets or sets the child node, i.e. the node that is moved by this joint.
JointTypevcLinkJointTypeRGets the type of this joint.
OffsetvcMatrixExpressionPropertyR
Access expression value via vcMatrixExpressionProperty
Gets the expression property which defines the PositionMatrix for the joint.
ParentNodevcNodeRWGets or sets the parent node, i.e. the node that is not moved by this joint.
PositionMatrixvcMatrixRW"
Gets or sets transformation relative to the ChildNode.
Note: Assigning new matrix overwrites the offset expression.
PropertiesvcPropertyContainerRGets the property container.
deleteNoneNoneDeletes this joint.
